Rev hang explanation... - Page 2 - Hyundai Genesis Forum
post #11 of 22 Old 11-12-2009, 09:13 PM
joseph_camron_price is on a distinguished road
subscribed
joseph_camron_price is offline
post #12 of 22 Old 03-28-2010, 01:42 PM
arghx7 is on a distinguished road
There's nothing new or unusual about the throttle not shutting immediately. It's always been that way on most fuel injected cars. The old cable driven throttlebodies usually had a damper installed (called a dashpot) so that the throttle wouldn't shut suddenly. The idle air control valve would also open further (Mitsu stepper type) as rpms increased or increase in duty cycle (Nissan, Mazda, Honda solenoid valve type). This is so extra air enters the engine if you let off the throttle, to keep the car from stalling.
arghx7 is offline
post #13 of 22 Old 03-28-2010, 02:08 PM
genjuice is on a distinguished road
10-FL-006 3/18/2010 GENESIS COUPE(BK) Fuel System 10-FL-006 ECM UPDATE - DTC P0605 OR SLOW RPM DROP WHEN RELEASING THROTTLE
genjuice is offline
post #14 of 22 Old 03-28-2010, 05:53 PM
NateV's Avatar
NateV is on a distinguished road
Even though that was released in March of this year it still just references the old update that came out originally. 149 - Logic Improvement, so this is not something new they just updated the procedures to correcting the problem. If you have The latest PA re-flash or the BR Maps loaded on your device then you already have it. I know I got this update several months ago and I verified my ROM ID and it's the same as the new ROM ID that your supposed to have after updating it.
HGC Light Blue 2.0T Built on 12 / 23 / 08 Accepted on: 4 / 7 / 2009
NateV is offline
post #15 of 22 Old 03-29-2010, 06:06 AM
BoostedGen2010's Avatar
Originally Posted by Shadouwynd View Post
Well, for all you 2.0T owners, after I replaced the OEM BOV with the HKS SSQV, it eliminated my rev hang completely. That was the very first thing I noticed immediately on the test drive.
Did the same mod to mine, got the AGP Kit that doesnt use the blockoff plate but leaves it in the stock location. Still get Rev hang, not as much or as bad but it is still there. Could only be fixed with a reflash. But it doesnt bother me to much anymore.
BoostedGen2010 is offline
post #16 of 22 Old 03-29-2010, 06:24 AM
Insane is on a distinguished road
The latest ECU update fixes the rev hang...was released awhile ago. Well, it does in the 3.8 anyway.
2010 Genesis Coupe
Nordschleife Gray 3.8 Track M/T w/NAV
Insane is offline
post #17 of 22 Old 03-29-2010, 11:54 AM
Mcmonopoly's Avatar
Mcmonopoly is on a distinguished road
Rev hang should only be experienced by the 2.0T crowd, the NA 3.8L shouldn't have this issue at all. No BOV present in NA cars....
2010 2.0T GT Genesis Coupe
Myster Noobness at your service!!
PowerAxle PowerX module
Mcmonopoly is offline
post #18 of 22 Old 03-29-2010, 12:02 PM
I understand that, but there was a rev hang issue with the 3.8 in most of the reviews of it. There was a TSB for it specifically. It's part of the reason the 3.8 A/T did better on the track than the M/T. However, it was ECU related. It sounds like you guys are talking about a mechanical rev hang issue.
I'm coming from a 2.3T car, (Speed 6) and I'm trying to figure out how the BOV/BPV would cause the revs to hang?
2010 Genesis Coupe
Insane is offline
post #19 of 22 Old 03-29-2010, 12:14 PM
Mcmonopoly's Avatar
From the first post of this thread:
Originally Posted by Tufast View Post
By Jay at SuperDrift
"Well, there has been many speculations and researches by shops, but we got this "unofficial" explanation straight from the horse's mouth. We can't name who, but he/she worked on the Gen coupe project.
The rev hang (partial opening of the throttle) was put into the throttle body control in order to lessen the blow by gas emission. During the development Hyundai researchers experienced that if a throttle body closes immediately, pressure inside the engine(crankcase) becomes so great, it caused more oil vaporization than usual. This is quite normal for any turbo charged engines, but Hyundai wanted even better emissions and didn't want to deal with the "oil loss" issues. Thus by partially keeping the throttle body open even after gas pedal has been completely released, pressure can escape from engine.
So, here is what we found out. Solution to the rev hang issue will be to fix the throttle body control codes in the ECU, install oil catch can and add oil every month.."
Makes a lot of sense, since it can be eliminated using different methods (PA flash, Aftermarket BOV)
post #20 of 22 Old 03-29-2010, 12:24 PM
Ahhh...I should have read the entire thread. That is an interesting way to keep the pressure down though.
I'll try to pay attention better before posting...my bad.
2010 Genesis Coupe
Insane is offline
genesis coupe , hyundai , performance , rev hang , tuning
