Too rich - Page 2 - Hyundai Genesis Forum
post #11 of 18 Old 07-01-2010, 05:01 PM
BoostedGen2010's Avatar
Did you put the stock injectors back in?
BoostedGen2010 is offline
post #12 of 18 Old 07-01-2010, 10:36 PM Thread Starter
No I am running way lean with the stock stuff.
Red Raspberry is offline
post #13 of 18 Old 07-04-2010, 08:40 AM Thread Starter
I did some logging last night. When the AF goes pig rich the Injector DC out goes blank displaying --.-- and Lambda pegs at .68. TP is correct and consistent. RPM is around 5600 but this does not always happen every time I hit 5600 rpm
I'm thinking the --.-- display/ .68 lambda is from the data going to 100%. The fuel tables are all populated at the same value of .76 in tat rpm range.
post #14 of 18 Old 07-05-2010, 08:01 AM Thread Starter
Well found out my problem was the CAN termination plug was not installed.
post #15 of 18 Old 07-05-2010, 12:30 PM
Poser!
Sabbasaun's Avatar
Good to know you got the problem fixed... any word on when CMD will be able to adjust timing?
Sabbasaun is offline
post #16 of 18 Old 07-11-2010, 08:44 PM Thread Starter
Well that was not the problem.
The problem was I did not have my fuel trim table 100% populated by at least .70 as a minimum.
post #17 of 18 Old 07-14-2010, 12:30 PM
CrookedH's Avatar
Just ran into a similar issue after loading my old 20psi map today. I was going to 100% duty cycle and the car would bog down big time. Disabled autotune and all was fine. I'll adjust the maps when I get some time and see if the problem comes back.
CrookedH is offline
post #18 of 18 Old 07-15-2010, 12:47 PM Thread Starter
Yes, after a day out "testing" I don't believe the CMD can handle the larger injectors and the sudden change back and forth between closed loop/constant throttle and open loop/ WOT.
Auto tune just keeps correcting itself, rich this time leaner the next.
