Gauges - Hyundai Genesis Forum
post #1 of 16 Old 01-31-2010, 07:38 PM Thread Starter
genjuice is on a distinguished road
Gauges
This is usually a good thread starter as well as educational .
If you could only choose three gauges what would they be and why.
The first two are easy,but the third one is always up for debate.
Also the third one cant be a obdII reader.
genjuice is offline
post #2 of 16 Old 01-31-2010, 07:47 PM
ragchaos's Avatar
ragchaos is on a distinguished road
Yeah i was wondering that too for the third gauge
Missing the Shit outta my car
MODS Installed:
Road Race Motorsports Intake
Adjusted Wastegate Arm( 1.5 turns)
CP-e Catback
CP-e Downpipe( catted)
HKS Blow Off Valve
SFR Pulley Combination
Oil Breather and Accumulator from AGP TURBO
DynoJet CMD 20psi
Stock Dyno 164rwhp 190lbs Tq
Now Dyno 216 rwhp 270 lbs Tq
52rwhp and 80lbs Tq gain on a Super Flow Chassis
ragchaos is offline
post #3 of 16 Old 01-31-2010, 08:14 PM Thread Starter
I forgot to tell mine, FPG.Watching that gauge could save you from a fire and also tell if your fuel system is working properly.
genjuice is offline
post #4 of 16 Old 01-31-2010, 08:16 PM
Shadouwynd's Avatar
Well, if anyone didn't plan to change the transmission, god knows why they wouldn't with all the cold start troubles, I'd say a Transmission temp gauge so they would know when it's warmed up nice so you'd be able to downshift into 1st, 2nd, or 3rd...
As for the extra third slot, I really don't know either. Maybe a voltmeter gauge. :shrug:
Or, if I was a mcgyver type guy or had a lot of extra cash laying around I would modify a boost gauge and rename it the happy meter, complete with a face that will frown or smile, depending on how much boost.
넌 날 벗어날 수 없어, 한국의 힘.
Shadouwynd is offline
post #5 of 16 Old 02-01-2010, 05:48 PM
Well here's your choices:
The ones in red will probably not make the cut, but I choose AFR, boost & oil pressure if OBII is not an option according to OP.^^
Air Fuel Ratio Gauge
Blower Pressure Gauge
Boost Gauge
Brake Pressure Gauge
Clock
Cylinder Head Temp Gauge
Differential Temp Gauge
Fuel Gauge
Fuel Pressure Gauge
Nitrous Pressure Gauge
OBDII Gauge
Oil Pressure Gauge
Oil Temperature Gauge
Pitch And Yaw Gauge
Pyrometer Gauge
Speedometer
Tachometer
Temperature Gauge
Transmission Temperature Gauge
Vacuum Gauge
Voltage Gauge
Water Pressure Gauge
Water Temperature Gauge
post #6 of 16 Old 05-17-2010, 07:24 AM
I just cobbled up three gauges over the radio display. Used an oil temp, volts and boost.
The oil temp is not connected yet. I was planning on taking off the oil filter mount and drilling and tapping that for the sender.
Red Raspberry is offline
post #7 of 16 Old 05-20-2010, 08:18 AM
fatflyguy is on a distinguished road
THE BIG THREE .....for the 2.0's anyway should be
Boost Guage
AFR wideband
and EGT (exhaust gas temp)
any more then you're just trying to be fancy.
TEAM NEXTMOD
Please come and check out the ONTARIO GENESIS CLUB on facebook!
fatflyguy is offline
post #8 of 16 Old 05-20-2010, 08:28 AM
Anyone know of a good place to put an oil temp sender?
FWIW if you don't have a tune or can't tune then the AF gauge and exhaust temp would be a waste IMHO.
If you can tune then a WBO2 AF gauge would definitely be worth it.
post #9 of 16 Old 05-21-2010, 02:22 PM
nope, AF is always a plus to have even if all you've done is a simple mod like your Intake. Every mod affect the AF in certain ways. and Exhaust temp, well I'm taking it as a given that most people will have modifed with a tune since it's the cheapest mod to HP you can buy!
TEAM NEXTMOD
post #10 of 16 Old 05-21-2010, 05:28 PM
joshua243487's Avatar
joshua243487 is on a distinguished road
anybody know when a gauge pod will be out, either a pillar pod or the dash one?..
R-spec FTW
joshua243487 is offline
