Genesis sedan TSBs and Campaigns - Hyundai Genesis Forum
post #1 of 9 Old 05-24-2009, 10:42 PM Thread Starter
Hyundai Employee
DayDreamer's Avatar
DayDreamer is on a distinguished road
Tufast and I have decided that we needed a place to post current Technical Service Bulletins (TSBs) and Campaigns (recalls) that are out for our cars. We will do our best to keep this as updated as possible, so check back every now and then.
Technical Service Bulletins are usually nothing but informative bulletins, stating specifications or proper procedures for certain things. They do not indicate that a problem exists. I will probably not post every single one of these unless it specifically has to do with the Genesis sedan because some of them cover numerous models over a number of years and aren't really useful for our purposes.
Campaigns, on the other hand, are recalls that are issued specifically for that particular vehicle for a specific problem. Every single one of these will be posted. Please be aware that just because a Campaign exists for your model of car doesn't mean that your specific car is affected. Campaigns usually cover very specific VIN ranges. A visit to your dealer will determine if yours is included in the Campaign or not.
Engine Mechanical
09-EM-001 (Unnecessary Engine Flush Services)
Fuel System
09-FL-009 MIL on With DTC P0456 **NEW**
Automatic Transmission
08-AT-013 (Neutral Start Switch Adjustment)
09-AT-001 (Gensis Coupe V6 and Genesis Sedan V8 Automatic Transmission Fluid Level)
09-AT-006 (Hyundai Specified ATF and Additive Usage)
09-AT-009 (TCM Calibration Update After Installing New Transmission)
09-AT-014 (TCM Calibration Update)
Suspension System
09-SS-002 Rear Hub & Driveshaft Isolation Washer Installation Procedure **NEW**
Brake System
09-BR-001 (Parking Brake Shoe Replacement Kit)
09-BR-002 (Stop Lamp Z01 Diode Inspection Procedure)
Body (Interior and Exterior)
08-BD-016 (2009 MY Genesis Exterior Color Codes)
09-BD-003 (Aluminum Wheel Cleaning and Maintenance) *PERTAINING TO "HYPER SILVER" WHEEL FINISHES
Body Electrical System
08-BE-007 (Resetting Electronic Components after Servicing Vehicle Battery or Fuse)
08-BE-008 (Genesis Key Cutting Procedure and Smart Key Programming)
08-BE-010 (Steering Wheel Power Tilt & Telescope Limit Switch Replacement)
09-BE-009 (Active Headrest Reset Procedure)
09-BE-010 (Wiper Blade Replacement)
09-BE-012 (Body Dimension Info)
09-BE-019 B1602 & 1603 Battery Drain Condition **NEW**
Heating, Ventilation, and Air Conditioning
09-HA-003 (Rear Console HVAC System Operation Inspection)
Campaigns
08-01-010-1 (Mid Grade Lexicon Audio System Amplifier Replacement - Campaign T55)
08-01-012 (ECM Update - 2009 Genesis DTC P2135 Logic Improvement - Campaign T56)
09-01-012 (DIS Navigation System Software Update - Campaign T63)
08-01-026 (Fuel Door Release Switch Replacement - Campaign T66)
09-01-006 (Airbag Control Unit Update - Campaign T79)
DayDreamer is offline
post #2 of 9 Old 05-25-2009, 05:10 AM
Thanks for the work guys. Good idea.
post #3 of 9 Old 05-25-2009, 06:55 AM
Thanks again DD, most props to ya.
post #4 of 9 Old 06-17-2009, 07:20 PM Thread Starter
Hyundai Employee
DayDreamer's Avatar
Bump for 2 new TSBs.
post #5 of 9 Old 06-30-2009, 07:09 PM Thread Starter
Hyundai Employee
DayDreamer's Avatar
Bumpity bump for 1 new TSB regarding Body Dimension information.
post #6 of 9 Old 06-30-2009, 07:10 PM
Thank you DD for keeping this thread up to date.
post #7 of 9 Old 08-05-2009, 11:40 AM Thread Starter
Hyundai Employee
DayDreamer's Avatar
Bump for new TSB. Sorry it's taken me so long to post it up, I've had some file hosting issues.
14.328 @ 97.67 mph
(Mods soon to come)
Genesis Coupe 3.8 Track, ZF automatic
Norschleife Gray
Diode Dynamics Stage 2 LED upgrade kit
post #8 of 9 Old 08-12-2009, 10:10 AM Thread Starter
Hyundai Employee
DayDreamer's Avatar
Bump for new TSB
14.328 @ 97.67 mph
(Mods soon to come)
Norschleife Gray
post #9 of 9 Old 02-25-2011, 01:51 PM
Gimli's Avatar
Gimli is on a distinguished road
Just an FYI, Hyundai Canada has issued two Customer Satisfaction campaigns for the Genesis. Customer satisfaction campaigns are kinda like recalls except they don't involve safety issues so they are not registered with the legislative authorities (NHTSA and Transport Canada).
They're coded C0100 and C0107 and consist of updates to the operating system of the entertainment centre as well as an update of the GPS maps to April 2010 (as opposed to April 2008 as delivered). My dealer performed both campaigns at no cost, although I had to leave my car in two consecutive days because of an error when they first tried the update, which takes a minimum of 4 hours.
Gimli
2009 Phantom Black V8 Hyundai Genesis sedan w/tech
Gimli is offline
genesis sedan , problems , Recalls/TSBs , warranty
