| Hyundai Genesis - Problems & Warranty Info This is where you can discuss any technical problems you're having the Hyundai Genesis platform or Warranty issues. |
| Hyundai Genesis - Problems & Warranty Info Thread, Genesis Coupe TSBs and Campaigns in Hyundai Genesis Discussions - General; Tufast and I have decided that we needed a place to post current Technical Service Bulletins (TSBs) and Campaigns (recalls) ... |
Tufast and I have decided that we needed a place to post current Technical Service Bulletins (TSBs) and Campaigns (recalls) that are out for our cars. We will do our best to keep this as updated as possible, so check back every now and then. Technical Service Bulletins are usually nothing but informative bulletins, stating specifications or proper procedures for certain things. They do not indicate that a problem exists. I will probably not post every single one of these unless it specifically has to do with the Coupe because some of them cover numerous models over a number of years and aren't really useful for our purposes. Campaigns, on the other hand, are recalls that are issued specifically for that particular vehicle for a specific problem. Every single one of these will be posted. Please be aware that just because a Campaign exists for your model of car doesn't mean that your specific car is affected. Campaigns usually cover very specific VIN ranges. A visit to your dealer will determine if yours is included in the Campaign or not. Technical Service Bulletins (TSBs) Engine Mechanical 09-EM-001 Unnecessary Engine Flush Services 09-EM-003 Engine Oil Specification and Service Interval 09-EM-004 Engine Air Filter Differences Fuel System 09-FL-011 Engine RPM Control Logic Update **NEW** 09-FL-010 ECU Update - DTC P0605 or Slow RPM Drop When Releasing Throttle **NEW** Automatic Transmission 09-AT-001 Genesis Coupe V6 and Genesis sedan V8 Automatic Transmission Fluid Level 09-AT-003 Genesis Coupe 2.0 Turbo Automatic Transmission Fluid Level 09-AT-006 Hyundai Specified ATF and Additive Usage 09-AT-012 TCM Calibration Update Driveshaft and Axle 09-DS-001 Rear Crossmember Mounting Bushing Steering System 09-ST-003 Genesis Coupe Power Steering Fluid Type Suspension System 09-SS-001 Staggered Tire Size Information Body (Interior and Exterior) 09-BD-003 Aluminum Wheel Cleaning and Maintenance *PERTAINS TO "HYPER SILVER" WHEEL FINISHES 09-BD-006 Body Dimension Information 09-BD-007 Door Belt Weatherstrip Change 09-BD-008 Quarter Inner Panel Noise Repair 09-BD-009 Front Bumper Cover Gap Adjustment Sunroof Slides Open http://genesisforums.org/attachments...-09-bd-015.pdf **NEW** Body Electrical System 09-BE-011 Rear Bumper and Clip Change 09-BE-017 Audio and Bluetooth System Update **NEW** 09-BE-018 SRSCM Programming Procedure (ACU Variant Coding) **NEW** Campaigns 09-01-009 Campaign T84 - High Mounted Stop Lamp Mounting Screw Replacement Last edited by Tufast; 11-15-2009 at 06:00 AM. |
| Sponsored Links |
Thanks DD this is great stuff... i was thinking about doing the same for the Sedan as well but in a separate post... you guys rock! |
THANKS A LOT. GREAT STUFF
"GOTTA LOVE ME" Mods=RRM Intake, RRM Fuel Controller, 7ism exhaust (race version), RRM Timing Module |
haha awesome thanks for the hard work!
Good job. We needed this. |
The Genesis Coupe Owner's Manual is pretty vague about what grade of oil to use. The bulletin on engine oil was a great help.
Thanks DD for stepping up & gathering this stuff, you rock.
If it ain't fast, I'm not happy. ![]() '04 Honda 450R (stupid fast) '87 Rockrawlin Wrangler All mods, little left factory |
#9
Yeah, I noticed that the diff is only held up by one bushings when I had it on the lift at work the other day. Im taking it that is normal and ok??
#10
Awesome stuff: I don't feel comfortable unless I've got a stockpile of this stuff. First thing I look for when I buy a car, new or used, is all the paperwork that's been generated over the release of the vehicle. Thanks!
--boozysmurf "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses." - Elwood Blues |
| Tags |
| genesis coupe , problems , Recalls/TSBs , warranty |
