Tufast and I have decided that we needed a place to post current Technical Service Bulletins (TSBs) and Campaigns (recalls) that are out for our cars. We will do our best to keep this as updated as possible, so check back every now and then.
Technical Service Bulletins are usually nothing but informative bulletins, stating specifications or proper procedures for certain things. They do not indicate that a problem exists. I will probably not post every single one of these unless it specifically has to do with the Coupe because some of them cover numerous models over a number of years and aren't really useful for our purposes.
Campaigns, on the other hand, are recalls that are issued specifically for that particular vehicle for a specific problem. Every single one of these will be posted. Please be aware that just because a Campaign exists for your model of car doesn't mean that your specific car is affected. Campaigns usually cover very specific VIN ranges. A visit to your dealer will determine if yours is included in the Campaign or not.
Automatic Transmission
09-AT-001 Genesis Coupe V6 and Genesis sedan V8 Automatic Transmission Fluid Level
09-AT-003 Genesis Coupe 2.0 Turbo Automatic Transmission Fluid Level
09-AT-008 Automatic Transaxle Stall Test Procedure
09-AT-012 TCM Calibration Update - Third Gear in Sports Mode
10-AT-002 Hyundai Specified ATF and Additive Usage
10-AT-009 CAN Codes U0101 and C1612 Diagnostic Precedures
10-AT-011 Automatic Transaxle Control Module - Reset and Relearn Adaptive Values
Body (Interior and Exterior)
09-BD-003 Aluminum Wheel Cleaning and Maintenance *PERTAINS TO "HYPER SILVER" WHEEL FINISHES
09-BD-006 Body Dimension Information
09-BD-007 Door Belt Weatherstrip Change
09-BD-008 Quarter Inner Panel Noise Repair
09-BD-009 Front Bumper Cover Gap Adjustment
09-BD-011 Sunroof Creak/Tick Noise Repair
09-BD-012 Inner Quarter Panel Creak/Tick Noise
09-BD-015 Sunroof Shade Slides Open
Body Electrical System
08-BE-012 Programming Homelink Mirrors to Garage Door Openers with Rolling Code Technology
09-BE-011 Rear Bumper and Retainer Clip Change
09-BE-017 Audio and Bluetooth System Update
09-BE-026 Alarm Self Activates - Hood Switch Pad Replacement
Driveshaft and Axle
09-DS-001 Rear Crossmember Mounting Bushing
Engine Mechanical
09-EM-001 Unnecessary Engine Flush Services
09-EM-002 CVVT Oil Control Valve Inspection
09-EM-003 Engine Oil Specification and Service Interval for Turbocharged Engines
09-EM-004 Intake Air Filter Element Differences for Genesis Coupe Engines
09-EM-006 Guidelines and Torque Specifications of Engine Fasteners Using the Torque-Angle Method
10-EM-003 Engine Oil Pump Replacement Guidelines During Engine Replacement
Fuel System
09-FL-006 Evaporative Emission System Diagnostic Information
09-FL-011-1 Engine RPM Control Logic Update
09-FL-015 Fuel Filter Service Kit for Genesis Coupe
10-FL-006 ECM Update - DTC P0605 or Slow RPM Drop When Releasing Throttle
10-FL-009 2.0L/2.4L Theta Engine ETC Throttle Body Cleaning
Restraints
09-RT-001 Supplemental Restraint System Control Module Programming Procedure (ACU Variant Coding)
Steering System
09-ST-003 Genesis Coupe Power Steering Fluid Type
Suspension System
09-SS-001 Staggered Tire Size Information
09-SS-009 Alignment Specifications - 2010 MY Passenger Vehicles
10-SS-002 TPMS (Tire Pressure Monitoring System) General Information
10-SS-003 Brake Fluid Precautions - Adding or Changing Fluid
10-SS-005 Disc Brake Machining Recommendations
Campaigns
09-01-009 Campaign T84 - High Mounted Stop Lamp Mounting Screw Replacement
09-01-028 Campaign T96 - Manual Transmission Gear Shift Lever and Oil Replacement
09-01-033 Campaign T98 - Manual Transmission Gear Shift Knob Replacement
09-01-034-2 Campaign T99 - Console Armrest Replacement
09-01-036 Campaign TA1 - Audio LCD Label Replacement
10-01-003 Campaign TA2 - Audio and Bluetooth System Update 2
10-01-021 Campaign TB5 - Automatic Transmission Shift Cable End-Rod Boot Replacement
Driveshaft and Axle
Engine Mechanical
Fuel System
Restraints
Steering System
Suspension System
Campaigns
