Gas pump nozzle pops out at gas stations
Go Back   Genesisforums.org - The Internet’s Premier Hyundai Genesis Sedan and Genesis Coupe Community Forums! > Hyundai Genesis Discussions - General > Hyundai Genesis - Problems & Warranty Info
GenesisForums.org is the premier Hyundai Genesis Forum on the internet. Registered Users do not see the above ads.
Hyundai Genesis - Problems & Warranty Info Thread, Gas pump nozzle pops out at gas stations in Hyundai Genesis Discussions - General; Brand new 2012 Genesis 3.8. In NJ where we do NOT pump our own gas. Attendent has to hold the ...
Old 01-27-2012, 06:44 AM
tsb1727 is on a distinguished road
Default Gas pump nozzle pops out at gas stations
Brand new 2012 Genesis 3.8. In NJ where we do NOT pump our own gas. Attendent has to hold the nozzle into the tank or it pops out. Anyone else have this issue?
Advertisement
Old 02-26-2013, 03:19 PM
EricinLA is on a distinguished road
Default Same Gas Pump Issue
I have a 2011 Genesis 4.6 fully loaded. I have the exact same problem. I have a hard time keeping the gas nozzle in for more than 20 seconds without holding it in. Bad design
Old 03-04-2013, 07:26 PM
I have not heard about this but sounds dangerous. Did either of you contact NTSB?
Old 03-18-2013, 06:42 PM
RainGage is on a distinguished road
Default Pump nozzle
This is probably not a Hyundai issue. In the US gas pumping equipment is changing to help seal in vapor while you fill your tank. For a decade they've been adding an expansion sleeve (like a bendable soda straw has) to the filler neck in an attempt to trap the fumes from going wastfully into the ambient air. I doubt they did much to help because a good seal was rarely made and the sleeves wear out.
Now new pumping equipment is showing up (2012 on) where if you relax the pressure enough to allow the seal to unseat too much it'll stop pumping fuel. A pain in the... but I do like trees, so...
Advertisement
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
VerticalScope Inc.
