| Register | Photo Gallery | FAQ | Members List | Calendar | Forum | Mark Forums Read | Auto Escrow | Insurance | Auto Loans |
| Hyundai Genesis - Problems & Warranty Info This is where you can discuss any technical problems you're having the Hyundai Genesis platform or Warranty issues. |
| Hyundai Genesis - Problems & Warranty Info Thread, Battery charge V8 in Hyundai Genesis Discussions - General; As an owner of a new Genesis 2011 4.6l Sedan, I have been getting vague answers from my dealer and ... |
As an owner of a new Genesis 2011 4.6l Sedan, I have been getting vague answers from my dealer and Hyundai Customer Service concerning the following :
When I park my vehicle in an airport parking lot for a three weeks out-of-town trip, should it start without a problem upon my return? What is a realistic time period that the Genesis can be parked before start-up? There are recommendations that for "long term storage" a battery maintainer should be connected which is easily done in one's own garage. |
| Sponsored Links | ||
Advertisement | ||
I leave vehicles sit for 6 months without starting and they are fine. You may have too many things that continue to run like the clock and alarm system. Just guessing here. You could disconnect the battery next trip but then you need to reset everything which is a PITA to reprogram the radio ETC.
wwtraveler, your Genesis sedan along with a few other vehicles by Hyundai (Equus, Veracruz & Entourage) have an array of electronic devices that draw on the vehicle even when shut off. Due to issues with these vehicles going dead while on the sales lot, Hyundai issues a TSB to crank the vehicles every couple of days or pull the stunt fuse out to disable most of the components.
http://www.amazon.com/BatteryMINDer-.../dp/B000JS268M
Just saying... maybe get one of these to leave in your window or something? I have used these before for RVing, jet skis, cars stored for winter... they work great
Clutchmaster Stage II Clutch Clutchmaster Flywheel PA Reflash w/Custom Tune Deatschwerks 550cc Injectors UR 3" High-flow Cat UR 3" Downpipe Custom 3" Exhaust (no mufflers) CP-e Intake StopTech Brake Upgrade Kit Beyond Redline FMIC 264WHP and 314WTQ **Coming** Beyond Redline GT2871R Turbo upgrade Winter tuning goal is 320WHP and 300WTQ |
Any thoughts? This is getting really frustrating. Thanks! |
It is very hard to track down an errant current drain. Here's how to do it.
You need an amp meter between the negative cable and the battery post. Then it needs to be mounted so you can see it while you start to pull fuses. You are looking for a drop. Seeing as some current drain is normal this can be quite frustration. Usually the nominal current drain is less that a 100mA. So with the battery draining down over night the drain is going to be bigger than that. Just start pulling the fuses and see if you can narrow down the circuit. |
| Sponsored Links | |
Advertisement | |
