Check engine light - Hyundai Genesis Forum
post #1 of 16 Old 02-07-2010, 09:48 PM Thread Starter
joshua243487's Avatar
joshua243487 is on a distinguished road
Check engine light
I did the radiator hose tb bypass today before i drove to work, it was pretty easy literally took 2 min. when i got in my car to go home, i turned on the car and the check engine light came on, i don't know if it was because of the hose bypass( I doubt it is) it might because of the actuator adjustment that i did like 3 or 4 weeks ago, the car is pretty much stock( been trying to buy this house lately) so ya basically i want to try and get an obd scanner so i can tell what the problem is when ever i get a cel, so..... does anybody know a good obd scanner that i can maybe buy locally like in a walmart, autozone, checkers, pepboys and so on. not looking for anything too advanced like reading rpms or 0-60 speeds, just want something to check problems- thanks
R-spec FTW
joshua243487 is offline
post #2 of 16 Old 02-08-2010, 07:47 AM
ragchaos's Avatar
ragchaos is on a distinguished road
Like you said check auto zone, last i check they had a nice one that was able to read and clear codes, if not auto zone try advance auto parts.
Missing the Shit outta my car
MODS Installed:
Road Race Motorsports Intake
Adjusted Wastegate Arm( 1.5 turns)
CP-e Catback
CP-e Downpipe( catted)
HKS Blow Off Valve
SFR Pulley Combination
Oil Breather and Accumulator from AGP TURBO
DynoJet CMD 20psi
Stock Dyno 164rwhp 190lbs Tq
Now Dyno 216 rwhp 270 lbs Tq
52rwhp and 80lbs Tq gain on a Super Flow Chassis
ragchaos is offline
post #3 of 16 Old 02-08-2010, 07:51 AM
AutoZone should read the codes for free. I would clear the code by disconnecting the battery and see if it comes back before getting too concerned.
Red Raspberry is offline
post #4 of 16 Old 02-08-2010, 10:42 AM Thread Starter
so i bought a scanner today just to have cause i want to know what codes the coupe is throwing, i plugged it in and it read P0076, tufast or somebody know what that code means or why i got it poping up?
R-spec FTW
post #5 of 16 Old 02-08-2010, 10:53 AM
DTC P0076
DTC P0076
Don't know where the VDI solenoid is but it has to do with the intake. Possible it is unplugged.
post #6 of 16 Old 02-08-2010, 10:58 AM Thread Starter
holy shit i'm sorry, when i did the hose bypass for the tb, i forgot to reconnect that plug( i disconnected it because it was in my way), thanks rasberry
R-spec FTW
post #7 of 16 Old 02-08-2010, 11:28 AM
ragchaos's Avatar
glad you got it fixed good call on the scanner you never know when you will need it whether it be for the coupe or any of your future cars
MODS Installed:
CP-e Catback
HKS Blow Off Valve
DynoJet CMD 20psi
ragchaos is offline
post #8 of 16 Old 02-09-2010, 06:08 PM
Hey just got to this thread, been busy....glad to see you got it fixed. The scanner is well worth the money, it will come in super handy.
post #9 of 16 Old 08-07-2010, 06:47 AM
Joshua, I was thinking about doing this radiator throttle body hose bypass mod & forgot the details of routing etc. Could you post a pic of yours completed to refresh my memory.
Thanks in advance.
post #10 of 16 Old 08-07-2010, 07:08 AM
The 3/8" hose comes out of the front of the engine and then 90s over towards the TB. It goes to a black plastic piece with two hoses attached. Plug that line or loop one of the hoses over so one hose connects to both ports.
I just removed them all and uses a short piece of hose to plug the port coming out of the head.
Click image for larger version
Name:	TB bypass.jpg
