| Hyundai Genesis - Problems & Warranty Info This is where you can discuss any technical problems you're having the Hyundai Genesis platform or Warranty issues. |
| Hyundai Genesis - Problems & Warranty Info Thread, Ignition Problem on my 3.8GT in Hyundai Genesis Discussions - General; Hey, where is this fuse located? I had the same problem ONCE in the 1st week of owning the car. ... |
#31
Hey, where is this fuse located? I had the same problem ONCE in the 1st week of owning the car. Drove it in 1" sleet on the road, felt snow, sleet pounding under the floorpan. Drove 7 minutes to parking garage then took train to NYC. I came back 11 hours later, everything still wet (temperature went up, and everything it got humid). I pressed the ignition button and the started just turned over and over for 10 secs. I pressed it off again, waited 2-3 sec, and then tried again, and have never had any problems since then (3 months). I thought maybe I should still check the fuse?
2010 Mirabeau Blue 2.0T 6MT with Premium Package 2005 Nissan Pathfinder LE AWD |
| Sponsored Links |
#32
If it ain't fast, I'm not happy. ![]() '04 Honda 450R (stupid fast) '87 Rockrawlin Wrangler All mods, little left factory |
#33
I think you are on the right track though as far as the problem - a loose or bad connection is what I am suspecting which may also present as a bad/loose fuse. Although, in my case not. Last edited by YogiBear; 03-04-2010 at 03:12 PM. |
#34
This issue is the same issue I had and it is defiantly a Proximity key issue, read my post and you will see it is the same problem. Prox key issue? Starter engages when already running!!! Also make note of what dash lights are on when this happens, it should be the car icon with the key in it, that light should not come on if the key is in the car, if it is on when the car is running and the key is in the car...DO NOT PRESS THE STARTER BUTTON! It will most defiantly grind the starter. ![]() Take your key and move it around or put it in the dash slot, but just wait for that light to go off first. |
