Go Back   Genesisforums.org - The Internet’s Premier Hyundai Genesis Sedan and Genesis Coupe Community Forums! > Hyundai Genesis Discussions - General > Hyundai Genesis - Problems & Warranty Info
GenesisForums.org is the premier Hyundai Genesis forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Hyundai Genesis - Problems & Warranty Info Thread, RPM Question in Hyundai Genesis Discussions - General; Hey guys, Just got my coupe (2.0T) over the weekend and I love it. Now I have a dumb question. ...
Old 09-05-2009, 11:26 AM
amohamed is on a distinguished road
Default RPM Question
Hey guys,
Just got my coupe (2.0T) over the weekend and I love it. Now I have a dumb question. Keep in mind I am in no way a genius with cars and this is the first time I have owned a "sports car." My question is, when going about 100 km +, is it normal for the RPM to stay constant at 2500 to 3000 rpm? And I guess higher if I am faster. Just wanted to know if this is normal (it is at about 3000 rpm at 120, then goes higher if I accelerate). Thanks in advance.
Advertisement
Old 09-05-2009, 11:47 AM
Lut3s's Avatar
Lut3s is on a distinguished road
Revolutions per minute - Wikipedia, the free encyclopedia
Waiting on R-Spec
Old 09-05-2009, 12:05 PM
YogiBear's Avatar
YogiBear is on a distinguished road
Is yours a 5 speed or 6? If 5 then for sure yes, if 6 then it should be at 2500 or less at 100 kmph. The only thing that affects rpm when the clutch is all the way out is the speed the car is going, generally speaking. Generally, 4 cyl motors have too little power at high speeds to stay low in rpm so they are geared for higher rpm at higher speeds - even when coasting. So ya ... unless you have a V-8 you typically will not be below 2,000 rpm at 100 kmph. I have seen big blocks idle around 2,000 at 100 kmph. The only time to worry is if you are not getting around 30 mpg economy (which is 12.75 km/l) with your windows up and a/c off with one person in the car. I can get 34. If you get less than 30 in normal air temp - like 70 deg F or 21 deg C - then something is wrong and your engine is spinning too fast.
Old 09-05-2009, 03:39 PM
Thanks for the info . Mine is actually an 5 speed so I guess its all good. Thanks again
VerticalScope Inc.
