Flutter and/or compressor surge - Hyundai Genesis Forum
post #1 of 6 Old 06-28-2010, 05:01 PM Thread Starter
CrookedH's Avatar
Some good info on bov selection, operation, and issues. Credit goes to Whatnot for the info:
Technically flutter only occurs with a BOV, and surge is with turbo... but that is more semantics than anything.
All fluttering noise isn't bad, as long as it goes away and has a changing frequency, as that is the BOV piston fluttering open and itís like a ball bouncing, how the frequency gets higher and higher until it stops, and itís more of a whistling sound.
Instead of gravity pulling on the ball, and the ball having less and less energy, bouncing lower and lower until it stops. The BOV flutter is blowing off some air, and less and less air is released until it stops.
It's basically from too tight of a spring. The air starts to get out, and then the pressure drops too low to compress the spring and keep the BOV open so it shuts, then the pressure builds again, so same process, it just doesn't open as long (why the sounds gets higher pitched), like I explained with the ball and gravity.
Some call it the turkey gobble or the pigeon call or flutter dump, its ok, and won't harm anything, you just have too tight of a spring. You can loosen it if you want to be rid of the sound, but you might have trouble holding higher boost. Here is a great video and you can actually watch the BOV flutter 9 secs in a correlate the "ball bouncing sound" as the BOV increases its frequency and higher pitch, and finally stops.
What IS bad is when the flutter is metallic, generally higher pitched to begin with and continuous, without change, as that compressor blade 'smacking' against the air and is generally a higher frequency as the compressor blade is spinning fast. This is bad for your turbo. It is much like too high of a back pressure, it never actually has the blades moving the other way, and it just puts a ton of strain on the bearings and shaft. There is no, less and less air or and slowing down (ball bouncing effect), itís a constant frequency beating of the blades.
This is also compressor surge, as you can see the BOV not even open and you hear the surging.
you really start to hear it @ 1:04. And the fluttering sound is constant not "bouncing down", and not as 'whistly' as a flutterdump.
But what is terrible to hear is when you are under load and you get flutter. like this vid.
If you are ever WOT and you hear a flutter, THAT, is VERY BAD. It doesn't even have to do with a BOV, as your BOV should be shut during boost, so how is a BOV causing a surge? It means your A/R is too small for the boost you are running (very unlikely as you engine will most likely blow up before this from the hot air), but most likely, your had some dirt or something that over time rounded off/clipped your compressor blade and the 'seal' (blade tip to housing clearance/tolerance) isn't as good and the blade beats/slaps the air vs., pushing it. Like if you cut the compressor blade in half, it would give you a little bit of boost at first, but then it would lose efficiency VERY fast and then it would slap the air, vs. compress and push it. It is not that 'bad' for your engine or turbo... as you turbo is already F'd lol. So it is bad news, and not good to hear, but youíre not damaging anything when you hear flutter/surge under WOT.
I have heard other opinions, but this is what makes sense to me anyway, and I have some logic behind it, so I am happy with it.
CrookedH is offline
post #2 of 6 Old 06-29-2010, 08:19 AM
Excellent post, stuck thread.
Also makes me rethink my BOV choice, this synchronic seems like the shit. I love the quick response & absence of loud whistle after shift. Anybody have any feed back regarding this type of BOV?
post #3 of 6 Old 06-29-2010, 10:06 AM Thread Starter
CrookedH's Avatar
Interested in some first hand feedback on the Synapse BOV as well if anyone has used them... I've got the Forge MS BOV I plan on using once I get my car back but was thinking about putting the Forge MS on my wifes car and getting a Synapse for me....
CrookedH is offline
post #4 of 6 Old 04-25-2011, 04:26 PM
boostcrzy's Avatar
boostcrzy is on a distinguished road
I've tried synapse when I had my evo and it worked relatively well. It is very temperamental and requires that you figure out what vacuum ports to connect for your particular setup. In my opinion I would go with a tial bov, they perform great and are very easy to install with minimum tuning.
boostcrzy is offline
post #5 of 6 Old 04-27-2011, 04:29 AM
I was going to go with TiaL until I learned about Synapse & then changed my mind. I didn't realize that they were that tempermental, but I guess it will worth it once I do have it dialed in.
post #6 of 6 Old 04-27-2011, 09:49 PM
My Tial works OK. If I were to do it again I would upgrade the OEM one and not do a cold side BOV. As it is with the BR tune the OEM one works great. The Tial is just a gewgaw now and in the way.
Red Raspberry is offline
