| Register | Photo Gallery | FAQ | Members List | Calendar | Forum | Mark Forums Read | Auto Escrow | Insurance | Auto Loans |
| Engine and Turbos This section is for discussing engine parts (for example, bottom or top end), turbos (upgrades, porting, etc), or other engine related parts or swaps. |
| Engine and Turbos Thread, DIY Throttle Body Radiator Fluid Bypass Decrease AIT Increase HP in Hyundai Genesis Discussions - Performance/Technical; Originally Posted by Tufast Thanks for the info & let us know what you come up when at WOT on ... |
#61
![]() I have an update today, my car was dyno tuned, the weather was relatively much cooler today due to heavy rain but still hot compared to USA spring, fall or winter weather. my car made 411whp, coolant temp got as high as 95C but the IAT got only up to around 50C at WOT pulls, big difference there.
| Sponsored Links | ||
Advertisement | ||
#62
time for me to post some data
![]() this pic is just after the 3rd gear pull at the dyno. Coolant temp was 96.5 *C and IAT was 40.3 *C ![]() max rev data during the pull, coolant temp was a bit lower at 89.1 *C and IAT at 39.4 *C ![]() I hope this helps
#63
What are you using to data log with?
#64
MoTec M800 ecu datalogs it, I open the datalog file with MoTec I2 standard software.
#65
#66
This was a common mod on the 1st Gen Mazda6s. While no one had any definitive measurements, most thought that they were less likely to lose power from heat soak. Being in the southern US, (Memphis) I was always looking for ways to keep the intake air cooler.
#67
Berdugo, that's pretty good results. I've done multiple mods in order to keep temps down and have more planned.
| Sponsored Links | |
Advertisement | |
