DIY Throttle Body Radiator Fluid Bypass Decrease AIT Increase HP - Page 2
Go Back   Genesisforums.org - The Internet’s Premier Hyundai Genesis Sedan and Genesis Coupe Community Forums! > Hyundai Genesis Discussions - Performance/Technical > Engine and Turbos
GenesisForums.org is the premier Hyundai Genesis Forum on the internet. Registered Users do not see the above ads.
Engine and Turbos Thread, DIY Throttle Body Radiator Fluid Bypass Decrease AIT Increase HP in Hyundai Genesis Discussions - Performance/Technical; Originally Posted by Tony20Tgen Actually on my LT1 I gained 7whp from this alone! and I would suspect on a ...
  #11
Old 02-02-2010, 02:31 PM
Originally Posted by Tony20Tgen View Post
Actually on my LT1 I gained 7whp from this alone! and I would suspect on a turbo car the gains would be the same. ALSO Your lazy not to try it before u talk shit about it!
TUFAST please erase his garbage comments off this sticky!
Sorry, can't do, because woomdawg had what he considered a valid point that was worth discussing. You on the other hand are the one that retorted with slandering comments like mindless, lazy & dumbass. That is not how we discuss topics around here, no name calling. I don't care if you cuss, just don't cuss at anyone, because it just derails the subject at hand & we end up talking more about each other than the OP. Since this is your thread (& I'm interested in it) I will cut you slack, but refrain from future mishaps.
Back on topic, I beileve that the mod will make a difference IMHO. We try to do everything we can to cool the air prior to going into the TB, using the likes of FMICs, intake manifold gaskets, CAIs, Ice boxes, etc etc. Why would we not want to do a simple free mod that should have an effect, unless said mod causes a harmful side effect. Since this is such a simple mod, I think that doing it in the spring & putting it back for winter may be a good idea for my climate considering how cold it has been this winter. Remember that most mods only yeild a few Hp anyways, it's the combination of a bunch of mods that makes a car fast & I will use every mod at my disposal to get as much out of this car as humanly possible.
Advertisement
  #12
Old 02-02-2010, 02:32 PM
CrookedH's Avatar
I think someone needs to be a little thicker skinned. I really don't think any of his posts were insulting, rude, or anything like that. Your replies to his posts though........... If one person questioning gains off of this mod gets you that worked up you're going to have a rough forum life.
Back on track... Nice write up. I never got a dyno done on my old cars with the same mod, but as Tufast mentioned, every last bit of heat you can block is good IMO.
Piggyback holding you back? Don't like canned tunes? Want control over your own cars tune?
NitroGen
The open source Genesis Coupe 2.0T ECU tuning project
www.williamworley.com/nitrogen.php
www.gencoupe.com/2-0t/46730-crack-stock-ecu.html
  #13
Old 02-02-2010, 03:15 PM
woomdawg's Avatar
Hyundai Employee
woomdawg is on a distinguished road
Sorry for my outburst if I am wrong I am man enough to admit it, all I was doing was adding my own insight. I apologize to the forum community. I still stick with my statement and dont really think you would see a gain from this,it's just my opinion nothing more.
I can't wait to get my R-spec !!!!
  #14
Old 02-02-2010, 03:21 PM
dic51's Avatar
dic51 is on a distinguished road
figure it out ur self then!
Are you serious? hahahahahaha!
I agree with Tufast and CrookedH. He took it personally and then in turn made it personal. I don't think Tony's a bad guy or anything, he just took it wrong. It's all good.
Genesis Coupe
Bathurst Black 3.8 ZF Track
  #15
Old 02-02-2010, 04:53 PM
woomdawg's Avatar
Hyundai Employee
So I started to think about this in a little more detail and i am positive I am right so let me explain. This coolant path is there to cool the throttle body , so engine coolant is around 200-225 thermostat opens at 180 and the coolant in the radiator is cooler than 180 so the an uncooled throttle body will have a temp of around 210-225 so hyundai cools it by running cool coolant from the radiator through the throttle body not coolant from the engine thus cooling the inlet air temp.The way I see it is you reroute this coolant in a loop as described in this post espicially in a hot climate aka miami you will loose HP. I am not trying to insult anyone at all just trying to educate.
  #16
Old 02-02-2010, 07:02 PM
You may be correct, I sure would like to take a bone stock car dyno it, do the mod & dyno again same day. I'm curious to see how it would turn out.
  #17
Old 02-02-2010, 10:29 PM
With the thermal spacer the two mods are a good deal.
  #18
Old 02-03-2010, 03:42 AM
NateV's Avatar
NateV is on a distinguished road
I will have to disagree with you, the coolant going through the throttle body has nothing to do with cooling. It is used for below freezing temps it keeps the throttle butterfly warm so that it does not freeze over and become stuck. That's why people that live in Miami would see the best advantage from this mod because they could use it year round.
HGC Light Blue 2.0T Built on 12 / 23 / 08 Accepted on: 4 / 7 / 2009
  #19
Old 02-03-2010, 04:03 AM
woomdawg's Avatar
Hyundai Employee
wrong
  #20
Old 02-03-2010, 04:16 AM
berdugo is on a distinguished road
I agree. I did this mod to my Subaru STi, and I'll do this mod too when I got myself a Genesis
Advertisement
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
VerticalScope Inc.
